I can't find the thread now, but it seems to me, sometime within the past two weeks or so, someone was asking Dennis about a pump or some such for a spraying rig. I dont remember the details, but Saturn Surplus has a 24 V pump that might fill your bill.
Scot, 24 VDC, Electric Pump Assembly.
Manufactured by Scot, Model #: 86, Part Number: 13217E7135, NSN: 4320-01-047-1927. Driven by a 24 VDC electric motor. Rated at 50 GPM @ 60' HD. Pump operates at 3, 450 rpm's with a 2" Inlet and 1 1/2" Outlet. Assembly weight: 111 lbs. Location: Bldg 5.
The above is the available information that came with the page. The part number might be theirs.
Hope that helps.
24 Volt Pump
This should be the link or at least the address to view the pump.
http://saturnsurplus.com/miscpage/1927.htm
Thanks Andy, I was the one asking (on the other forum). I will have to check this out. Looks like it would work well for bulk transfer but will have to see if it can handle the backpressure of being used for a sprayer pump. Also will check into the power usage to make sure the Pinz electrical system can keep up with it.
Lloyd
Lloyd
Have you checked with Dultmeier Sales? They have a place in Davenport.
www.dultmeier.com
1-800-553-6975
I've used them for oddball stuff on some of our DOT spray rigs out here.
www.dultmeier.com
1-800-553-6975
Mike Newton 1973 712M (sold)
